Removing Ambers
Manarius
Removing Ambers
Post by Manarius »
So, I'm thinking about removing my amber inserts this weeked (it's nice and all). I was also thinking, how about those white things behind the red plastic...I think vikash called them diffusers. Can I remove those too, or is that not a good idea?
I'm just thinking of what I can do while I have the cases off the car.
bmxkelowna
Post by bmxkelowna »
i tryed to get my tail lights off once and i had all 4 bolts off but they would not budge how come?
magicmike
Post by magicmike »
they are sealed to the sheet metal with butyl. you have to pry them off carefully. a little heat would help also.
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
smh0101
Post by smh0101 »
I still cant figure out how to get the ambers out of my '93 turbo (sedan). If you know how would you give me some pointers?
THX
You shouldn't remove the amber inserts; they play a role in forming the beam pattern of the turn signals.
92whitelegacy
Post by 92whitelegacy »
Take the backing off the sedan tails, from inside the trunk. Use needlenose pliers and just pull and tweak the orange piece untill you coherse it out of there. Takes no longer then 5 mins. I find this a no safety hazard, you will need orange bulbs though, cause the stock ones are white. Or do like me and get BRIGHT red ones JDM all the way :twisted:
92 ss 275k+mi, kartboy shifter/bushings, gauges. VRG3 FCD II, NGK I'4s, TDO5-16G 4" dp CAT-less 3"tbe 4.11 gears.
ohwee
Post by ohwee »
I sweat a bucket coercing those things out. They will frustrate you but don't give up! I found that a heat gun helps.
1993 Turbo Sedan 4EAT, 2000 Outback Limited
THAWA
Post by THAWA »
92whitelegacy wrote:I find this a no safety hazard
Except for the fact that it is.
