OMG OMG!!!
OMG OMG!!!
I should be able to drive my car this week!
Full list of modifications is as follows:
Transmission: PPG 1-4 Straight Cut, Synchro gearset. Temporary solution for a problem with my dogbox. RWD.
STi Short-Throw Shift Linkage w/ Kartboy short shifter. REAL short.
TurboXS Front Mount Intercooler, Painted stealth.
Custom Intake
4-1 unequal length headers.
KYB AGX struts, STI Pink Springs
Subframe brace, strut tower braces.
Over the next week:
22mm front, 24mm rear sway bars.
Lots of camber and castor.
Beginning of summer:
Unsprung 6-puck clutch
Doggin
LSD
Possible Guttification
And a bit more to come.
I'm so excited, I have to go to the bathroom!
Custom Intake
Over the next week:
Doggin
LSD
RWD won't hurt the tranny at all.
Pics and hopefully video will follow. Tranny will only be in for a week or so, then it's back to AWD and no synchros.
Re: OMG OMG!!!
burnout vids plzBAC5.2 wrote:Temporary solution for a problem with my dogbox. RWD.
snowboarded
greg donovan
on tonights monster garage jesse drove an ice cream truck that had no tire on its left rear drive wheel. in his attempts to get it onto the shop lift the wheel caught fire and dug a long groove into the concrete shop floor and threw sparks like a giant angle grinder.Yukonart wrote:Holy crap, Phil . . . now you just need to throw on some wheels with no tires from your other thread and tear-up the road!
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
00 Impreza RS sedan
For RWD, a new guy at the shop gutted a stock center diff. Since you can't just run a splined bar from the output shaft to the transfer gears.
The pinion shaft cannot be removed, because that's what holds the output shaft together.
Since this is an AWD trans, we simply swapped the spool in, and left all of the front-drive stuff in place. Won't cause any damage. Dan, the creator of the diff, ran around like this for a while before blowing up his rear diff.
Front axles will still be connected.
I will still be running the R160. I intend to run the R160 in the future too. Unless something better comes along.
We've had professional race cars running 650whp (and then nitrous on top of that) through a stock R160 with no problems.
With the 3.90 rear diff in the Legacy, my effective final drive in RWD mode with this tranny is 4.29:1. I'm banking on this being a lot of fun!
rallysam
Damn Phil. When is it going to be ready for me to come by and see?
'00 Impr RS - sold
I see a "Burnout of the Month" in SCC for this...
Legacy Central
Muahaha, good idea Dave! I DO have a spare set of wheels. I need a line-lock and my dogbox so I can run it through 4th.
The race car is AWD. The rear diff has a Quaife, but stock ring and pinion.
Sam, soon enough grasshopper.
its not as good as a line lock and a little hard on your rear brakes, but you can lightly hold them as you burn out. you are going slow enough that it should stop the car enough to get em started lighting up.
what is this piece to make awd-rwd? this sounds like something I might want to try.
I made a custom rear bushing a long time ago. WAY before Kartboy released their rear bushing. I'm using a stock STi front bushing for now.
How much power was he making?
I am definately concerned about blowing up the diff. But I'm also not, because what better way to do it, than in a glorious, smoke filled haze?
