replacement options for a 95 legacy 4EAT?
greg donovan
Post by greg donovan »
aside from the obvious, what year 4EATs will be a drop in replacement for my trans. in my 95 legacy wagon?
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
Manarius
Post by Manarius »
95-99 IIRC
greg donovan
Manarius wrote:95-99 IIRC
that is what i am thinking too.
i could use other years but i would have to swap out the front diff i think.
96 Impreza L sedan
00 Impreza RS sedan
Manarius
Post by Manarius »
If you use 90-94, you'd have to swap the TCU because the 95-99 do not have Power Mode.
OBDII also kicks in with the 95+ models.
greg donovan
what was power mode again?
was it where it would stay in gear longer?
96 Impreza L sedan
00 Impreza RS sedan
mikec
Post by mikec »
Yeah
greg donovan
mikec wrote:Yeah
my 95 will rev to redline on each shift if i mash the gas.
did they just make the power feature automatic in the second gen legacies?
96 Impreza L sedan
00 Impreza RS sedan
