Spare tire with WRX wheels?
thefultonhow
Post by thefultonhow »
I was talking to Gnuman on the IRC channel yesterday, and mentioned that I was going to get WRX wheels and then use my steelies as full-sized spares for long trips. He said that this would be a bad idea because the smaller diameter would cause torque bind. Is this true? If so, how far would I have to drive with a steelie on to cause torque bind?
-- David
1990 Subaru Legacy L+ 4WD Wagon 5MT, white with 66k miles -- SOLD
[url=http://www.g20.net/forum/showthread.php?t=66214]1992 Infiniti G20 5MT[/url], White Sandstone with 175k miles
Manarius
Post by Manarius »
It won't cause torque bind, but it will fry the center diff. Torque bind comes from aging 4EAT's.
Post by 555BCTurbo »
Just make sure the overall diameter is the same (read: taller tire on the 15" rim)
206er
Post by 206er »
a stock wheel/tire is a lot better than a space saver spare.
hmmm maybe I need to pick up a wheel/tire off craigslist. for some reason there is always someone selling one wheel. :? :-D
thefultonhow
555BCTurbo wrote:Just make sure the overall diameter is the same (read: taller tire on the 15" rim)
What if I run it with the stock tire size... torque bind? Or would I be okay for a hundred miles or so?
-- David
douglas vincent
Post by douglas vincent »
I picked up a spare wrx rim and tire for $50. Fits in the wagon wheelwell if nothing else is there.
Subtle
Post by Subtle »
If you are out in the boonies and had a tire failure I would sooner drive out on a more standard tire and rim.
What was the tire size on the 16-inch WRX rim :?:
thefultonhow
Subtle wrote:If you are out in the boonies and had a tire failure I would sooner drive out on a more standard tire and rim.
Standard WRX size -- 205/55R16. Eventually I will replace them with 205/50R16 to be closer to the original circumference.
-- David
Post by BAC5.2 »
206er wrote:a stock wheel/tire is a lot better than a space saver spare.
Why? The space-saver-spare is the same diameter as the stock wheel.
I use a WRX wheel with a stock RE92 (205/55/16) as the spare for my 17's.
thefultonhow
Phil -- what tire size is on your 17s?
-- David
Post by BAC5.2 »
225/45/17
thefultonhow
Oh... so the circumferance is pretty close. Darn.
How much would it cost to get a roughly matching spacesaver tire until I can get another WRX wheel?
-- David
Post by BAC5.2 »
Get a WRX space-saver and call it a day.
That's what I'd do.
thefultonhow
Hah! Didn't think of that. Thanks.
-- David
Yeah, I picked up a WRX spare tire as well since the stock one wouldn't fit over any of the brakes.
thefultonhow
Ooooooookay.
So I got a WRX spare tire from a guy locally. It was never used -- he got a full-size spare and put the stock one in his garage. The sizing on the spare is 135/70-16.
Okay, fine, but I found a set of WRX wheels locally with almost-brand-new tires. They are Falken Ziex ZE-502, but in a completely non-standard size -- 205/40-16 (stock is 205/55-16). So I went to Miata.net and calculated the tire size differences between the stock size, the size of the tires on the wheels I may be getting, and the spacesaver spare. I wanted to know if I needed a new tire for the spacesaver to prevent torque bind.
The results were surprising:
Code: Select all
Specification  Sidewall  Radius  Diameter  Circumference  Revs/Mile  Difference
205/55-16         4.4in  12.4in    24.9in         78.2in        811        0.0%
135/70-16         3.7in  11.7in    23.4in         73.6in        860       -5.8%
205/40-16         3.2in  11.2in    22.5in         70.5in        898        0.0%
135/70-16         3.7in  11.7in    23.4in         73.6in        860        4.4%
Well that's weird. Subaru's OEM spacesaver for the WRX is a completely different size than the WRX wheels. Wouldn't that cause torque bind? My curiousity was piqued, to say the least. So I wondered whether our cars had different-sized spacesavers too. I went outside, opened up the hatch, and took a gander at the spare.
The size? 135/70-16! The exact same size as the WRX spacesaver! WTF mate?
Here's a calculation from Miata.net for the stock wheels and spacesaver:
Code: Select all
185/70-14         5.1in  12.1in    24.2in         76.0in        834        0.0%
135/70-16         3.7in  11.7in    23.4in         73.6in        860       -3.1%
So, does wheel diameter not matter for torque bind?
-- David
Post by entirelyturbo »
Torque bind doesn't happen on 5MT's, only on 4EAT's.
The 4EAT clutch pack will TRY to make the fronts and rears spin the same speed and get really mad when it realizes they can't, while the 5MT viscous center diff will just kinda let it happen and wear itself out faster.
*Formerly DerFahrer*
thefultonhow
subyluvr2212 wrote:the 5MT viscous center diff will just kinda let it happen and wear itself out faster.
How much faster? If I were to run on a stock wheel/tire for, say, 500 miles while on a cross-country trip, would the diff be toast afterwards? Or would it just take several thousand miles off the (probably fairly long) life of the diff?
-- David
