Lightweight flywheels
georryan
Post by georryan »
Hey, you guys that have them, did your car idle funny for a while after you put them in? Specifically at stop lights and just sitting idle?
My car idles pretty solid at 750 rpms, but randomly and without much reason it will drop to 650 or even 575 for a second. It will lope down there for a short time and then pop back up again. Is this something I should expect and just realize the ecu will learn around it eventually?
-Ryan
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
DLC
Post by DLC »
Both mine, Exedy, acted completely normal on the 93 Turbo and the 00. IF you haven't already, try resetting the ECU, maybe some sensor is confused. I had a similar problem after an engine wash, and a CEL, but an ECU reset cleared up both the CEL and funny idle.
Legacy Central
georryan
Post by georryan »
Hmm. Well I'm not throwing any codes. I had a knock sensor issue, but I fixed that already, and yes, I do believe the ecu reset. At least I think it did.
2014 Volvo S60 T5
gt2.5turbo
Post by gt2.5turbo »
hmm... so what is our car suppose to idle at? cause once warm mine def sits at like 300-400 at lights and such
93 White Legacy Turbo Wagon: For Sale-ish
93 White Turbo Sedan: soon with a little more umf
91, funky brown purple gray color, legacy L Wagon: the "its so cheap i cant not pass it up" purchase to get me around when the others are down
Splinter
Post by Splinter »
gt2.5turbo wrote:hmm... so what is our car suppose to idle at? cause once warm mine def sits at like 300-400 at lights and such
Are you sure?
The tach doesnt go that low.
dscoobydoo
Post by dscoobydoo »
Mine still idles at around 650-750 after the lightweight flywheel. The tach actually reads as it being lower than it really is.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
georryan
Post by georryan »
I got my numbers from the vrg3 scan tool.
I'll have to check the plugs and make sure they are gapped and in tight enough. I'm betting it is a fuel issue, and it could be that the plugs aren't grounding well enough.
2014 Volvo S60 T5
Mine idled a little funky, but I attribute that to other things. If I ever get around to installing that new IAC valve I got from Phil, I'm hoping my idle issues will go away.
georryan
Post by georryan »
IAC valve. You know, that could be a contributing factor as well, but I would figure that would be more of an idle going too high and dropping back. This is the opposite.
2014 Volvo S60 T5
DLC
Post by DLC »
Well, just as a reference, my 00 2.5 with current mods idles at around 700, by the tach, which should be pretty accurate in this newer car.
Legacy Central
scuzzy
Post by scuzzy »
yeah, for future reference those of us using the stock rpm gauge - the second lowest most marker is the 500rpm mark (the one nearest the bottom marker)
stall speed on our engines is somewhere around 300-400 rpms
#82 M4 TRSCCA Rallycross
gt2.5turbo
scuzzy wrote:yeah, for future reference those of us using the stock rpm gauge - the second lowest most marker is the 500rpm mark (the one nearest the bottom marker)
good to know makes a lot more sense
georryan
Post by georryan »
Ok, I'm moving my dicussion to another topic since i don't think it is related to the lightweight flywheel.
I've moved it to this post here:
http://bbs.legacycentral.org/viewtopic. ... 440#171440
2014 Volvo S60 T5
