ok so im going to be pulling my motor out soon and need to tow the car to its semi final resting place. only problem is i cant afford a flat bed.
so will the fwd fuse still work? and if i put the car in "N" will that alow it to not mess up the trans??
towing a car with no motor or battery.
-jason
I think pulling the driveshaft is the only safe way to do it. Putting it in neutral doesn't really do anything for saving the tranny
