Is this goal realistic?
Judge Smails
Post by Judge Smails »
hi, i have a 92 legacy turbo 5 spd with 144K miles, runs good, all stock, anyways i am looking to achieve these goals with it:
0-60 time of 5.9 secs
so probably 250 bhp?
reliable enough for daily driver
in order to achieve this i need a solid plan and my budget is $3k. can this be done? thanks for your time!
Post by 555BCTurbo »
I've basically done that, for about $1500
PM me for details
Post by BAC5.2 »
Standalone, tuning, maybe an intercooler of sorts. That'll meet all of your goals.
But reliability depends on the standalone you choose. Piggy-backs tend to be the most reliable, because you don't have to worry about cold-start tuning and such. The stock ECU will control AC and all that nonsense too.
dzx
Post by dzx »
not difficult at all. You could get a 16G turbo and intercooler and be set. Pick up some bigger injectors and a safc II for safety.
///M
'93 Legacy SS - part out
Subtle
Post by Subtle »
Can it be done in 6 seconds----in the wet :?:
That would be cool 8)
Yukonart
Cradle Robber
Cradle Robber
Post by Yukonart »
But do you have to overnight parts from Japan to make this work?!?!?!!? :lol:
1994 & 2005 Legacy GT Wagons
Judge Smails
ok, so i need a 16G turbo, an intercooler, and a safc II? and then i was thinking wrx stock exhaust and then an ugraded clutch, any reccommendations for the clutch? where can i find all of this stuff? Sorry this is such a over used question probably.
Brat4by4
Stratified
Post by Brat4by4 »
Stock WRX exhaust will not help you much. A 3" turbo back exhaust really helps relieve pressure off the turbo and makes it more efficient. A WRX aftermarket exhaust can be easily fitted with some custom brackets that any competent muffler shop can fab up. At the very least you need a different downpipe since the OEM design is great for emissions but horrible for power making.
Best clutch is a stock Exedy clutch. Upgrade to a WRX clutch and flywheel. The flywheel can be stock WRX or the Exedy lightweight flywheel. If you really want an upgraded pressure plate go with the Exedy stage 1 clutch assembly. Notice any patterns in what clutch/flywheel products you should use? (Daikin is also Exedy.)
snowboarded
Post by snowboarded »
Don't forget about wheels, if you want to make a bunch of power, you want a wheel that can keep it on the tarmac.
With more power comes a need for upgraded brakes, imo.
[quote="Manarius "]Only flamers will get those. [/quote]
[quote="All_talk "]How many WHP will that give me? :)[/quote]
2010 Subaru Impreza 5mt 5 door
dzx
Post by dzx »
oh yeah, forgot about the exhaust, drop in K&N airfilter maybe and a downpipe.
///M
dzx
Post by dzx »
I wouldnt mess with the uppipe, its just fine stock.
///M
