What on EARTH
What on EARTH
We were driving up our driveway (a hill) and the engine just stopped. No coughing sputtering, nada. It was running fine no major problems. Im stumped. When I tried starting it again it just cranked like it was trying to start like normal but would never go. Anyone have this happen? Any ideas or suggestions to try. Could it possibly be the fuel pump?
How low were you on fuel? Sounds like it might have sloshed to the rear of the tank, away from the sock, if you were low enough.
Then again, it could be the pump too.
-Chris
91SS 4EAT stock, 200k mi
i just have this feeling its the fuel pump. a primitive way of checking would be to go out and take off the cover to the fuel pump, in the trunk. and then take a soft hammer and hit the top of the fuel pump a couple of times. and then try starting it. if it starts then you most likely have a bad fuel pump. this method isnt always 100 percent acurate but, its pretty damn good.
-93 2.2T (RIP), 93 N/A best car on earth.
-00 legGT, 18" PIAA sport mesh wheels, front/rear Rallitek sways, lowered whitelines, coming soon: 2.5L sti internals, 20g heads P&P, twin charged. motor is almost ready to go in.
Andrew
Andrew
Do you hear the fuel pump prime when you turn the key to the on position?
I'd try to check fuel pressure using a fuel pressure gauge. Just hook it up and turn the key to ON. If fuel pressure builds and holds, then it's unlikely that it's a fuel delivery problem. Unless you have a clogged rail or injector or very dirty and gross fuel filter.
Oh man Pull your rear seat. It's only two bolts. On the passenger side is an electrical connection. Check that connection to see if it is black on the inside or if it has a faulty connection. I've met three people with turbo legacies that had the same problem you had, as did mine. It was that electrical connector. I have another thread around here somewhere talking about trying to figure out what the problem was.
Mine died on the freeway at 60 mph. My friend bounced around in the back seat some and the car came back to life and kept going. haha
Basically that connection feeds power to the pump; when it cuts out, your pump no longer sends fuel. I ended up splicing the wires and just going around that connector altogether.
Good luck, hope this is it, because it is a simple fix.
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
2014 Volvo S60 T5
Right, the connector under my backseat had burned and melted at one point too, it's probably that.
-Chris
