Please note shipping is from Brampton, Ontario, Canada. Use www.UPS.ca and my postal code "L6Y-3J3" to calculate your shipping costs in CDN funds.
Listed prices are in Canadian funds, make offers on any parts from the legacys and state if in USD$ or CDN$. Thanks guys.
II currently have a few cars i'm parting out and some interior parts from the track/rally cars, I can start pulling some items now but any major stuff will have to wait until I start the tear down process
1) 1992 Legacy Turbo Sedan (complete car minus engine/tranny)
- black exterior/grey turbo interior
2) 1992 Legacy Turbo Wagon (complete car minus engine)
- black exterior/93 black turbo interior (this car was a late 92 model)
- 4EAT
3) From 1993 Impreza L Sedan
- 1.8L FWD
- 5MT w/ 2nd gear whine
4) From 1992 Legacy Turbo Sedan
- complete interior minus the dash
- complete sunroof assembly and glass (no leaks)
- complete working A/C system
- hard brake lines (ABS model)
5) 1991 Infiniti G20; great winter beater or fixer upper
- Automatic
- SR20DE
- Sunroof
- Fully loaded
- Tan leather interior
- 240,000kms on chassis ~40,000 on engine
- A/C does not work
- needs body work
6) 1987.5 Jaguar Sovereign XJ6
- Charcoal Silver on Gray leather
- Automatic
- 6 Cyl
- email for more info please
also from a '91 turbo (aka chrome handles)
- set of spare doors in black w/red pinstripe, fronts have glass
Items I'm planning on keeping (From Turbo legacys 1 & 2)
- both blocks
- 5spd tranny
- sedan dash
- alloy wheels
Aside from that most everything else is up for grabs.
Parts that may be of interest:
- 2 Turbo Crossmembers (perfect for any GC/BG swap)
- 18mm Rear sway bar fits BC & GC
- VENTED rear brake setup
- hoodscoops and spoiler
Other stuff:
- Pre-made lines with factory fitted 1/2"NPT ends (for oil coolers and filter relocation kits); $10 (not braided line on left)
- Go Fast Bits MBC in silver, used but comes with complete original packaging; $50
http://www.gofastbits.com/index.php?par ... ion=atomic
- 4x Michelin Pilot XGT H4 205/60/15 3/16" tread depth; $150 (tire on right)
- 2005 Legacy Outback Front (L&R) complete suspension shocks/springs/top hats, brand new dealer take offs (<200kms) don't think there is even rust on them; make an offer
- SAAB FMIC, rad style with plastic endtanks; $50
- New OEM Hella Fogs (Dodge Ram), glass lens with adjustable mounts w/9006 55w bulbs; $50 pair (L&R)
No pics yet for the following:
- Kingdragon 4pt harness (1x), made in italy, blue 2"belts (used); $75
- OEM Legacy GT Spoiler green (2000-2004) new without mounting hardware; $100
New Items as of 04/30/06; OBO unless otherwise listed.
- Polyurethane rear sway bar bushings
- 24mm for heavy duty mount
- Whiteline 22mm for heavy duty mount
- Whiteline 22mm for stock mount
- Stock WRX Bypass Valve
- OEM Tweeter Kit for 1995-97 Legacy, brand new.
- OEM Tweeter Kit for Forester, brand new.
- HKS Turbo Timer (not sure if type-0 or 1) w/WRX Harness, scuff marks on top and minor scuffs on face; $80
New Item/Pics as of 05/08/06
Corbeau Clubman seat, provisions for 5/6pt harnesses, w/ passenger side bracket/slider for GC/BC, worn where white leather piece is; $100
- 2000/01 RS 6-Spoke rim (only 1) w/ Goodyear 205/55/16 Tire, some minor chips and scuffing, perfect as a full size spare; $100
- 02 WRX TMIC; $125
Free:
- 2.5" Fart Can
- 2x Pirelli Winter tires 15" not much tread left
Reasonable offers accepted. Higher res pics by email. Items can be picked up in brampton. Thanks
SOLD Thank you.
- Bomz underdrive aluminum crank pulley with belt (<500kms on this, selling since I run lots of aux lights) fits EJ series motors; $75
- BSCI FIA 8857-2001 Type A Homologated Roll Cage Padding; 1 3/4" - 2" (QTY = 1) & 1 1/4 1 5/8" (QTY = 2), all are uncut and unused lengths of 3ft w/adhesive backing; $20 each (normally $22USD + shipping/duties etc)
- STi uncut keys (x3), larger of the 2 subaru key sizes; $25
- Misc 3"Dia. Intake section with 3x PCV fittings 3"OD; $10
- ABS cut off switch, will plug in where your ABS fuse goes and includes inline ATO fuse holder, just needs mounting (wire allows for mounting within 3ft of fuse box); $10
- Set of 4 center caps for 2000/01 RS 6 spoke rims
- WRX Hoodscoop, painted flat black and notched to fit around windshield sprayers
- WRX stock intercooler y-pipe
