WTB: A shorter clutch master cylinder -wrx?-
stipro
Post by stipro »
I need to buy a shorter master cylinder, so I can install me tmic. The reservior on mine is much too tall.
napphappy
Post by napphappy »
Take off the "hose clamp" remove the resevior cut the bottom off and reinstall in reverse order.
stipro
Post by stipro »
napphappy wrote:Take off the "hose clamp" remove the resevior cut the bottom off and reinstall in reverse order.
Really?
How much should I cut off? How much capacity is actually needed for proper function?
It seems so simple :D
free5ty1e
Post by free5ty1e »
Yeah, I cut off a bit of mine too (after picking up a spare reservoir neck from Subaru, about $12) when I had my TMIC in there.
The reservoir is just that, a reservoir. I only cut off up to one of those lines, but you should theoretically be able to cut off as much as you want. You just have that much less reserve fluid.
-Chris
91SS 4EAT stock, 200k mi
stipro
Post by stipro »
Well I am going to try it today and see if I cant get the car started sometime today.
Thanks for your help.
Even though this is in the parts shed, it sure was cheap :-D
napphappy
Post by napphappy »
We all bout cheap here.
stipro
Post by stipro »
Word!!
