OK, ever since I put on the Whiteline HD rear swaybar mounts, I get a small clunk which seems to be coming from the pass rear side. It is intermittant depending on the corner, speed and angle.
The 01 RS has this same affliction. Both cars were slowly modded in the rear suspension wise, and both seemed to have developed this clunk after the final install of the HD mounts.
NOW, I am guessing that the HD mount dropped the swaybar just enough so that now it is coming into contact with something under the car ( EG: exhaust, etc)
Anyone else have this issue??
Rear clunk
dscoobydoo
Rear clunk
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
05 GD-STI
00- GF
Disconnect the bar from the endlinks and move the bar and see if you get any contact between it and the chassis.
