Grinding Cast Iron
Grinding Cast Iron
What tool would you use to grind a piece of cast iron 5mm?
In what application?
Do you have a flange that you need to grind down to 5mm thick, like a flange on the passenger side collecter?
If so, I'd use a large circular bench grinder, a new wheel, a steady hand. The biggest mistake you can make is using a piece of shit Harbor-Freight grinding disc. Quality will get the job done in 1/3 of the time.
A friend of mine had a 12" bench grinder, and that sumbitch would handle ANYTHING.
Just do like Jeremy said, go slow. You'll heat the iron to red-hot and you could warp it. Wear gloves! I've got a slice in a pair of mechanics gloves from that grinder I mentioned. They actually saved my finger from getting sliced up.
I'm grinding a knuckle I only need 4-5 mm off of it. So like an angle grinder? Doing it on the car is much more advantageous than removing the whole thing.
You need ro remove 5mm? An angle grinder with a fat ass wheel should do the trick.
You could try cutting it too, using an air cut-off tool and a really high quality wheel.
I was actually taught in Machining School to never wear gloves when grinding...more people lose fingers when the gloves get caught in the grinder
I will vouch for the Angle Grinder and Quality wheel for this application...I honestly wouldn't worry about heat too much, because Knuckles are pretty stout, and it would take a lot of heat (i.e. rosebud) to heat it enough to cause cracking or warpage.
