Grinding Cast Iron
Posted: Wed May 10, 2006 4:33 am
by THAWA
What tool would you use to grind a piece of cast iron 5mm?
Posted: Wed May 10, 2006 4:41 am
by 206er
a regular grinder
go slow to keep the heat down.
Posted: Wed May 10, 2006 4:55 am
by BAC5.2
In what application?
Do you have a flange that you need to grind down to 5mm thick, like a flange on the passenger side collecter?
If so, I'd use a large circular bench grinder, a new wheel, a steady hand. The biggest mistake you can make is using a piece of shit Harbor-Freight grinding disc. Quality will get the job done in 1/3 of the time.
A friend of mine had a 12" bench grinder, and that sumbitch would handle ANYTHING.
Just do like Jeremy said, go slow. You'll heat the iron to red-hot and you could warp it. Wear gloves! I've got a slice in a pair of mechanics gloves from that grinder I mentioned. They actually saved my finger from getting sliced up.
Posted: Wed May 10, 2006 6:07 am
by THAWA
I'm grinding a knuckle I only need 4-5 mm off of it. So like an angle grinder? Doing it on the car is much more advantageous than removing the whole thing.
Posted: Wed May 10, 2006 6:44 am
by BAC5.2
You need ro remove 5mm? An angle grinder with a fat ass wheel should do the trick.
You could try cutting it too, using an air cut-off tool and a really high quality wheel.
Posted: Wed May 10, 2006 7:07 am
by 206er
oh a knuckle is probably going to be cast steel and on something that thick just fuckin go at it with an angle grinder.
the reason I said go slow on cast iron is not only will it warp but it will crack pretty easy if it is on the potmetal side of quality.
Posted: Wed May 10, 2006 12:37 pm
by corsair
BAC5.2 wrote:A quality angle grinder with a fat ass wheel should do the trick.
fixed it for ya Phil
Posted: Wed May 10, 2006 8:14 pm
by 206er
an $8 harbor freight angle grinder will last if you do a few mods to it and dont abuse it, and when they go it is usually brushes which are an easy fix.
but then you have actually purchasing a power tool at harbor freight on your conscience :lol:
Posted: Wed May 10, 2006 10:04 pm
by 555BCTurbo
I was actually taught in Machining School to never wear gloves when grinding...more people lose fingers when the gloves get caught in the grinder :shock:
I will vouch for the Angle Grinder and Quality wheel for this application...I honestly wouldn't worry about heat too much, because Knuckles are pretty stout, and it would take a lot of heat (i.e. rosebud) to heat it enough to cause cracking or warpage.
