Quick question: Stock hoodscoop removal...
Imprezive
Post by Imprezive »
I just found a stock wrx hoodscoop, I'd like to put it on when I repaint the car. I wasnt sure how it would look, so I tried taking the stock scoop off but I couldnt, how the heck do I do it? I tried to take off the bolts, but They just turned. Is there some kind of technique???
1988 4Runner RIP
2006 Suzuki DRZ400sm
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
Take a vice grip, and grab the bottom end of the bolt, then use a wrench to loosen the nut.
When you get the scoop out, take the bolts out, and epoxy them into the scoop.
Imprezive
Post by Imprezive »
thanks, I wasnt sure if I broke it or what
1988 4Runner RIP
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
Imprezive
Post by Imprezive »
didnt work, it just broke the little tip of the bolt off, I sprayed them with PB Blaster, hopefully that will help break them loose
1988 4Runner RIP
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
