pcv system
thehookeup
pcv system
Post by thehookeup »
i am puting a new oil catch can on my car tomorrow. but my PCV system seems to be pushing out a lot more oil then its supposed too. is there a reason for this. the head change, couldnt change this could it?
-93 2.2T (RIP), 93 N/A best car on earth.
-00 legGT, 18" PIAA sport mesh wheels, front/rear Rallitek sways, lowered whitelines, coming soon: 2.5L sti internals, 20g heads P&P, twin charged. motor is almost ready to go in.
Andrew
napphappy
Post by napphappy »
Where is the oil comming out?
thehookeup
the pcv system is working just fine, it just seems to be flowing a lot more oil than its supposed to. i have no leaks, its just dumping a lot more oil into the intake than i think it should be
Andrew
my3awds
Post by my3awds »
Excessive blowby can be caused by worn piston rings I believe. If you have access to a leak down testor, that would tell you if your rings are going bad. If your car burns oil or has low compression on certain cylinders, that would also be an indication of bad rings.
I think restrictions in the PCV system also can cause blowby, causing excessive pressure build up.
Subaru Impreza Ver6 replica with Ver4 Type R motorset.
Mitsubishi Evolution 4 replica with Evo4 GSR motorset.
thehookeup
i just rebuilt the motor. brand new oem rings. i have
175
180
182
178
compression
Andrew
Post by entirelyturbo »
I doubt it's the rings.
What kind of PCV valve are you using? If you're using an aftermarket one, it might be letting too much manifold vacuum through and literally sucking oil out of the crankcase. Always use an OEM PCV valve.
*Formerly DerFahrer*
All_talk
Post by All_talk »
Poor ring seal is the number one reason for excessive blow by but a bad head gasket can do it to… Your compressing numbers likely rule out both.
You sure the oil is coming through the PCV system? Bad compressor seal maybe?
Gary
thehookeup
well i think i narrowed it down. i am not using the stock pcv valve. infact im not using it at all. i took it out and put a plug in. and ran it straight to the inlet on my turbo. i was gonna put a new catch can on it. but i never got to it. i am gonna do it tomorrow. i am obviously pulling more through it then it would through the valve. so.. it should be cured tomorrow. not to mention i havent been burning oil. which lol means i must have a little oil in the bottom of my intercooler. i just didnt figure i was gonna pull that much oil. cause i have only been running it for a few days. i just noticed a little coming out of my BLV. ill post when its fixed
Andrew
