![Embarassed :oops:](./images/smilies/gear_oh2.gif)
facing foward or backwards
i want to know what is the difference in some suby's where the throttel faces foward and some facing backwards ![Embarassed :oops:](./images/smilies/gear_oh2.gif)
Suby tech on the way
you can just flip it around.
it requires moving the alternator to where the AC compressor used to be, making it impossible to keep the AC.
depending on the IAC valve, you may have to do some coolant line rerouting.
its pretty cool stuff, there are a bunch of threads on NASIOC including a write up.
