I just bought a JDM gauge cluster. It uses the VSS for the speedo. I know you can buy electronic converters. My question is what would it take to make one? It cant be that hard right.
The conversion factor is 0.621371192
Or does anyone know of a schematic for one online already.
KMPH to MPH Speedometer Converter?
You're talking about for your touring wagon?
Our stock setup has a spinning cable going from the transmission to the speedometer, and a VSS built into the speedometer.
To use an electronic speedometer at all, you'll need to get a later-model VSS that threads into the transmission and wire it into the speedometer and the ECU.
I don't know if this is even a possibility (since it might be impractical or ugly), but have you considered transplanting just the face of the stock speedometer gauge to your new cluster? Or repainting that part of the cluster?
No its for the outback. It already uses an electronic VSS for the speedo. I just need to slow the signal down so that it reads MPH instead of KMPH.
I thought about switch the dials, but it wouldnt line up.
Glad I asked. You should probably specify which car when you ask questions about the Outback here.
Do you think you'd be willing to tolerate the error produced by using a ratio of 0.5 instead of 0.62? Cuz dividing the frequency by two would be dead easy to do.
Well, give me a little while to think about it. I think reducing the frequency to 60% shouldn't be too hard. I'm thinking a CD4017 decade counter and a 74F38 open-collector buffer might do the trick. Email me at vikashgoel at gmail dot com if I don't reply within a week.
