Legacy trans?
AdamRS
Legacy trans?
Post by AdamRS »
I need to replace my automatic tranny in my 93 turbo. I was wondering if there are any other legacys I could get the tranny from, besides the 90-94 turbos. I know that the turbo legacys had a final drive ratio of 3.90, so the NA ones from those years won't work.
Adam
There are some 92's & 93's with 3.9 gearing.....however I'm not sure if it's a true 1:1 ratio between front & rear, or if it's like the WRX with 1.1:1
However the trannies on the turbo legacies 91-94 are stronger then the normal ones......but should work......
