Legacy outback 2000, is it 4.111
mhrallyteam
Is the 5mt from the legacy outback MY2000 a 4.111 final drive. I'm about to buy one to replace my 2.5RS tranny, i'm 90% sure they are the same, anyone 100% sure?
92 l swapped to ej22T with 2.0T shortblock
4.111 manual 2.5RS tranny, sti eng mount, wrx I/C, MBC, WRX turboback exhaust, WRX front seats, STI rad cap, WRX specR1 struts, Eibach springs , leg turbo front brake, WRX rear brake.
My 00 GT is, so it should be.
Legacy Central
mhrallyteam
mhrallyteam
Well, i'm just swapping the tranny, but i don't know if the rear diff is LSD or not, i did not buy it with the tranny. I should check, just in case, but i dount it is.
Project_Legacy
The 00-04 LGT and 00-01RS are rear LSD with 4.11 ratios.
Legacy Central
http://forums.nasioc.com/forums/showthr ... ost4261365
I found this helpful
