Under the rear window, behind the seats. There are three tapped holes for a 10mm bolt, one in the center at the furthest to the rear, and two at either side, about 6 inches away
Any idea what these are for? I was going to use them to build a custom mount/case for my carPC
Drilled & tapped holes in parcel shelf?
IronMonkeyL255
No clue.
I've seen people use those for mounting harnesses before.
Rio Red '91 Legacy SS
greg donovan
dscoobydoo
thefultonhow
They are. I was just looking at the green piece of paper about them that came with the car yesterday. On the wagons they're actually on the ceiling...greg donovan wrote:they could be used for infant seat restraints. there should be something in your manual about them.
-- David
1990 Subaru Legacy L+ 4WD Wagon 5MT, white with 66k miles -- SOLD
[url=http://www.g20.net/forum/showthread.php?t=66214]1992 Infiniti G20 5MT[/url], White Sandstone with 175k miles
IronMonkeyL255
That's what I was thinking they were for, since the new scoobs have latches (or something) there from the factory.
Score.
They'll make a perfect mount then.
I just scored a 20gb 1.8" drive which is nearly indistructable (200G operating shock rating), so Ill run that as my system drive, and mount the media drive on a USB extension inside the removable stereo box.
That way I can pull out the more fragile 3.5" drive when Im racing, and still keep GPS and engine diagnostics running.
IronMonkeyL255
