brake calipers
Townsville Liberty
brake calipers
Hi will the 4 pot capipers of a newer wrx fit up to the hub on a 92 lx? or do i have to change the hub? wat ubout the rear 2 pots of the wrx?
Originally Posted by Zefy
ahhhh... so many ideas, so lazy...:-p (not to meantion complete lack of $)
1st gear is just like foreplay, it's ok, but you want it to go as fast as you can and get it out of the way so you can get into the real sh*t!
dscoobydoo
The front ones should bolt up, but you will need the rotors also. As for the rears, you will either have to change the backing plates, or a few companies sell adapters to fit them to your existing backing plates. Again for the rears you will have to change the rotors to match also.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
05 GD-STI
00- GF
Townsville Liberty
Yeah i figgered that id have to change the rotors (id want to anyway) and since im already converting it to AWD i may as well fit thr backing plate to fit the rears while im at it
i was just wounderin weather there was a significant difference between the cars and from your reply there isnt much if any
thanks
thanks
