max boost with awic
max boost with awic
does any body have a rough idea how much boost can be ran thru a awic before it heat soaks?
93 turbo legacy
97 legacy gt wagon (rip)
2000 legacy l (rip)
1990 legacy wagon
2000 legacy l (rip)
1990 legacy wagon
I ran 15psi with no problems or detonation with a completely stock AWIC setup.
This was with a VF8. Remember, if you use a smaller turbo, you may be making alot more heat at higher boost levels.
