In preparation for the white wagon to be sold this week (yes, it's getting sold
NOPE!
The wheelstuds are destroyed on this car (who woulda thought??), so I was going to pound them out while the hubs were still on the car, like I did with Patti. But, it's not that simple on this car, because the ring on the hub that the ABS sensor reads will prevent the studs from coming all the way out after being pounded out.
So, it's 5 past 8pm, and I haul ass over to Sears, because they're the only ones open. I buy a grinder, a right angle attachment, and some metal cutting discs, to the total of $143.75. I go back and cut the threads of the studs off, so that they're short enough to come out completely when I pound them out.
Okay, taken care of. No more worries right?
WRONG!
I get everything else off, and then I get to the ABS sensor on the hub. I remove the nut, and try working it loose. Nothing. I tap a flathead screwdriver in the little ridge underneath it. Nothing. I go check my Haynes manual and double-check that the bolt is the only thing holding the sensor to the hub. I stick the flathead under the bracket off to the side of the sensor, and the head finally works under the bracket, but the bracket only bends upward
I keep hitting at it with a flathead for about 5 more minutes, and FINALLY, it starts to work its way out. I keep working at it, working at it, and another 5 minutes later, it's free.
The passenger side was worse than that.
Worse yet, I'm worried if I damaged the sensors in the process.
So, anyway, as I was saying, ABS sucks, and I never want to own another car with it.
/rant
I'm gonna get in the shower now.
