front end seals
front end seals
so i gotsta do my timing belt, and i might as well change all the front end seals, since im leaking oil amazingly badly when i don't run goop. What all seals are back there? Would someone mind posting a shopping list?
This might help: http://bbs.legacycentral.org/viewtopic.php?t=982
i agree napphappy...
Basically, Front Main seal. Cam seals.
But most important; the little oil pump o-ring.
And then permatex Ultra Grey for the oil pump.
and water pump( while your in there you might as well do it for a extra 4 dollars)
-93 2.2T (RIP), 93 N/A best car on earth.
-00 legGT, 18" PIAA sport mesh wheels, front/rear Rallitek sways, lowered whitelines, coming soon: 2.5L sti internals, 20g heads P&P, twin charged. motor is almost ready to go in.
Andrew
Andrew
The o-ring seals the oil discharge port between the pump and block.
You can see a pic of the passageway in this pic
http://www.main.experiencetherave.com:8 ... P_2710.JPG
if you order your seals through a subaru dealership they will know what you are talking about. its a small O-Ring at the discharge between block and the pump. look at the link
Andrew
Andrew
- quasi-mod-o
