Drifting/ RWD conversion
Has anyone converted their SS to RWD? I would love to see what these cars could do on a drift outing...I have heard that it is just a billet piece that replaces a piece in the tranfer case and eliminates the splines that drive the front axles...is there a kit made to do this?
92 SS--up and running finally!!
(edited for Jason Grahns pleasure)
BACS5.2 has done this, do a search.
Legacy Central
if you can find a better write up than this please show it to me.
http://www.clubwrx.net/forums/showthread.php?t=27532
I think that rwd is an interesting thing to try, but this is better used for putting an ej drivetrain into a rwd car. subarus are blessed with awd, might as well use it.
you could get the weight back behind the front axle because of how short it is, its very low CoG, very light motor, etc. perfect for a locost or whatever else light rwd that it will fit in. Ive been dreaming of a justy with rwd and a high compression ej25 in it...
I did it. It was pretty fun.
With your current setup, there is no kit short of converting your stock center diff.
Convert to an RS rear-section of the trans (the two aluminum rear cases, the center diff, and the transfer gears) and then you can easily set it up.
PPG makes a rear-drive conversion spool that drops in, in place of the center diff, and away you go in RWD.
I did it, I may or may not do it again. The car handles pretty well RWD, but the way my alignment is set up, it rotated a LOT under almost every type of condition. Did nice burnouts though. Wheel hop wasn't really an issue, but I don't have stock suspension.
Bushings and strut valving. Using AGX's and Pink springs, I didn't have an issue. I DO have stock bushings for the time being, but even then I didn't have MUCH an issue.
The biggest factor, I would think, is the bushings on the lateral links, as those control vertical movement. The trailing arm bushings deal with fore and aft movement.
My final drive changed to 4.29:1 so I can't say much about drivetrain loss. Probably not a noticeable amount.
It's people like you that are the reason there were sequels.bmxkelowna wrote:did you see any subarus in f&f3? no, for a reason
And by that I mean, people that bought tickets.
I disassembled one of my spare center diffs and it uses no clutch packs to send power to the front, it's just locked in for the 50/50 torque split. It is put together in such a way it's essentially already what the WRX guys weld up in order to convert. So wouldn't it stand to reason that if I removed my front axles I would send 100% power to the rear tires? ![Confused :?](./images/smilies/icon_confused.gif)
Remove your front axles and your front hubs explode.
I don't think you are looking at the center diff correctly. The diff is setup to split power 50/50, but it isn't a spool (total weld, locked 50/50 power split).
![Laughing :lol:](./images/smilies/icon_lol.gif)
![Wink :wink:](./images/smilies/icon_wink.gif)
http://www.clubwrx.net/forums/showthrea ... 532&page=5
Scrolling down to the picture on this page, my diff is on the left. What is there to weld together? I may very well be looking at it wrong, IDK. I'll take another look.
Phil, did you convert an SS tranny or a WRX tranny? I'd really like to try this before it snows and the real fun driving begins! (AWD of course.
![Cool 8)](./images/smilies/icon_cool.gif)
Looks like the older diff can't be converted. I guess you could weld the spider gears in place, but maybe not. You could switch to a WRX welded center diff and use the 1:1 output gears from a newer RS (for which you'd need the rear most cover of the transmission too).
I used a WRX trans when I was RWD (Straight cut syncro box).
I'd much rather just work on getting enough power to all 4 wheels to break 'em loose and dorifto whenever I feels like it with AWD. I'm having a lot of trouble accepting that someone would want to convert an AWD Subaru to RWD... does not compute ![Confused :?](./images/smilies/icon_confused.gif)
To each their own, I s'pose.
-Chris
91SS 4EAT stock
91SS 5MT awaiting engine rebuild and VF36...
92SS 4EAT - RIP![Sad :(](./images/smilies/icon_sad.gif)
94SS 5MT4.11+rLSD 289k km: RobTune550,TD05-16g @ 18psi,FMIC,3"TBE,Forester lift
91SS 4EAT stock
92SS 4EAT - RIP
Talk to Nate AKA Drftsub. I plan on making mine RWD soon.
The cool thing is if you can snag an extra center diff to keep as your RWD converter diff you can swap out the two whenever you want AWD/RWD. Summer vs. Winter. know what I mean?
1988 4Runner RIP
2006 Suzuki DRZ400sm
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
1988 4Runner RIP
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
Exactly. I just installed a 6-puck unsprung clutch with my LW flywheel and pressure plate and I'm afraid I'll break another tranny (which I just installed this last weekend). I figure if I'm RWD, the tires will spin before I break a gear, possibly. Don't get me wrong, I love AWD down the dirt roads and trails around here, but I don't do any real agressive driving on pavement.Imprezive wrote:The cool thing is if you can snag an extra center diff to keep as your RWD converter diff you can swap out the two whenever you want AWD/RWD. Summer vs. Winter. know what I mean?
Read my sig.Imprezive wrote:What kinda of flywheel are you running? How heavy is it?
http://www.optionimports.com/su00a-531.html
This is it, but I got it used with the matching pressure plate for much less than that.
![Razz :P](./images/smilies/icon_razz.gif)
You'll break something when RWD. You are sending double the power to the rear of the car.
RWD is pretty fun. I would have liked to be RWD for a little while longer with better tires and a more aggressive (RWD spec) alignment. It handled well, but it was a totally different feeling.
Breaks axles every time? that must suck, I have yet to break an axle and I have been running rwd w a "spooled" rear diff ( welded, more consistant for drifting ) for a year now and have yet to break anything. If I were breaking them that much I would either convert to sti rear diff/axles etc or get some custom axles made.
But...
The transfer shafts in the rear of the trans are the part that will most likley break. You could get an extra set out and send them off to get cryro treated to help in strength, or maybe get some custom ones made that are stronger.
My car handles well rwd, it is predictable and tracks well, although right now I am looking at building a bellhousing for a true rwd transmission and moving the engine back to get some better weight balance, run a r200 rear diff to get some more strength for the new engine setup.
But...
...::Slide your ride::...
[url=http://www.driftsub.com/]^driftsub^[/url]
[url=http://www.sloganizer.net/en/]>I wish i was a driftsub<[/url]
Yes make sure you have stubs in the front hubs if you pull your axles out.Binford wrote:Yes, I realize I'd need to put the stubs in the hubs for the wheel bearing to ride on and to keep the wheels on.
Phil, did you convert an SS tranny or a WRX tranny? I'd really like to try this before it snows and the real fun driving begins! (AWD of course.)
ok, on the diff ,
the older one is actually better to modify if you are going to do it as the "top" positivley engages with the body.
open it up, pull EVERYTHING out till you get to the last splined output ( under the spider gears ) clean that and the housing very well. weld that part to the body, if you really like you can add some material in there to support it to help with strength too .
that is all you have to do, once welded allow to cool ( dont "toilet temper" it ) and thats it.
I have converted a wrx trans, and a 98 2.5 rs trans ( which is the same type of conversion as the SS ) so it does work.
