Any advice for dropping the steering rack?
IronMonkeyL255
Post by IronMonkeyL255 »
Looks like I'm gonna have to drop my steering rack soon...
It's been leaking ever-so-slightly for a while now, but it looks as though it has chosen now to start pissing fluid and a greater rate than normal.
I already tightened all the fittings I could get to without dropping it, but that doesn't seem to have done the trick.
Anyone have any advice?
Rio Red '91 Legacy SS
To drop the rack, you need to loosen the u-joint holding it to the steering wheel rod. Mark the position of the splines so you can install it back the same way.
Pop the ball joints off, and loosen the fittings to the pump, and the rack should come out relatively easy.
IronMonkeyL255
I don't need to fully remove it, just far enough so I can get to all the fittings to tighten them up.
206er
Post by 206er »
personally, I wouldnt drop it unless absolutely necessary. our crossmembers are made so that water can get in and sit in the brackets that hold the rack. I broke 3 out of 4 of the bolts, and believe me, that is not a bolt you want to break. drilling out broken bolts is never fun, doing it lying on your back and getting showered with shavings is even worse.
