Anyone tried this?
Posted: Sun Jun 25, 2006 5:17 pm
So i was taking a look at some pictures/measurments i took a while back concerning installing a meghan racing dp to an 05 sti mid and turbo back. I determined i would need a 3.5" extension pipe to make this work.
As is i have the stock system to the sti turboback. It sits about 2.5" too far forward on the stock midpipe to use the stock hangers, even with the long kartboy hangers. It is currently held up by wire untill i get materials to make the dp work.
So now that i look at my pictures i see that the stock midpipe is slightly shorter than the meghan, nearly 3"
OEM VS STI mid + meghan dp
so i was wondering has anyone used the stock midpipe with the sti turboback and a longer dp? The way i see it the extra length on the dp would move the turboback back far enough to use the rear hangers. Though i would loose use of the rear mid hanger. Though i would finally have this damn DP in
Thoughts?
Thoughts?
