Thanks to Jake, Tristan, Trevor and everyone else, but......
dscoobydoo
Post by dscoobydoo »
Ok, convoying back from the meet, my car decided to have issues.
This is my thanks to everyone who was helping out get me back on the road.
Sadly, the issue was bigger than a few sensors.
Seems a bolt holding a timing belt sprocket sheared off.
Took out the belt, chunks off the water pump, oil pump and the lower half of the belt cover.
You don't even want to know what this is costing.
But the car will be going again tomorrow Tuesday night.
Seems the paint job/ new turbo will have to be on hold for a bit.
Pictures of the carnage later to come.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
Yukonart
Cradle Robber
Cradle Robber
Post by Yukonart »
Oh man. . . I'm not liking the sound of this. . .
1994 & 2005 Legacy GT Wagons
Adam West
Post by Adam West »
My condolences comrade. Jake's family will take good care of you. You are in good hands!
Yikes, that blows.
jake15
Post by jake15 »
ah, thats ghey man!!!! that explains the cam sensor code though. if you need any parts or help just give me a call :-)
dscoobydoo
Had to have it towed to Vancouver Subaru because they were close. It's now Tuesday at Noon and I am finally going to get the car.
05 GD-STI
00- GF
dscoobydoo
One small sprocket nut sheared,so the sprocket and nut bounced around inside the timing belt area. Took chunks out of the timing belt, killed the water pump, took chunks from the oil pump and destroyed the cover. The bottom of the cover is cracked and has burn marks from where it hit. ( Figure the engine was moving at 3100rpm, so this had to be spinning at least that fast. )
05 GD-STI
00- GF
Manarius
Post by Manarius »
Holy smashed stuff batman. Glad to hear your car's okay though.
dscoobydoo
Pretty much, but my belt was not as bad.
05 GD-STI
00- GF
franticfour
Post by franticfour »
Do ya think the bolt was over tightened or the idler bearing failed to break the bolt?
I think 90% of the time the idler fails first and destroys the belt, but with the bolt broke?
Good thing these are not interference engines :)
dscoobydoo
The idler was ok bearing wise and the belt is good enough to be re-used ( would not do it, but in a pinch it will get you there) The bolt sheared quickly for some reason. (you can tell because of how the metal left no jagged edges)
05 GD-STI
00- GF
Richard
Post by Richard »
Man, that's gotta suck. I really don't need that happening to me.
franticfour
It's possible the tensioner was bad and couldn't keep the belt from slapping or the bolt was over tightened or a little of both.
