Splinter
Post
by Splinter »
I just turned up my boost back up (first time since the tranny swap) and Ive noticed a weird misfire feel at full boost
Its somewhat reminiscient of when I had a slightly loose sparkplug and the spark plug boot was getting blown off, but not as violent
Possibly the spark is getting blown out? Should I go to a colder range?
scuzzy
Post
by scuzzy »
I'd start with checking the gap and condition of my plugs. Replace them to see if that helps.
better a misfire than a ping.
#82 M4 TRSCCA Rallycross
Post
by vrg3 »
And check the wires. Make sure they're okay and that they're firmly snapped onto the plugs.
napphappy
Post
by napphappy »
depending on how much boost, you may want to run a smaller gap.
Splinter
Post
by Splinter »
Im getting the miss at around 13psi
FuJi K
Post
by FuJi K »
humm....boost cut?
MY99 GF4 5spd DIY Modified
Splinter
Post
by Splinter »
no, Ive got an FCD
and boost cut is a lot more violent than this
vaccine
Post
by vaccine »
have you got the std coil on plugs?
one might be shot?
.. Dave
napphappy
Post
by napphappy »
No he has wasted spark ignition. But it does sound like it might be he coil.
