Engine cuts out
Engine cuts out
I have a 1994 twin turbo Legacy estate. The engine warning light came on and engine started to cut out above about 2500-3000rpm. If I turn engine of and restart no light and all is ok. If light comes on again it starts to cut out again. Something smells hot near front of engine but no signs of overheating and radiator remains cool. Any ideas.
Welcome. It is helpful if you put your location in profile. I am guessing England, but with a name like that maybe Wales.
Anyhoo.
It sounds like something is putting you in fail-safe mode. If you connect the black test connectors under the dash, turn the key to ON. Then the ecu will flash any trouble codes that are in the memory.
Anyhoo.
Thanks, am in North Wales. Is their anywhere I can get the trouble codes from.napphappy wrote:Welcome. It is helpful if you put your location in profile. I am guessing England, but with a name like that maybe Wales.
Anyhoo.
Im not sure what year of Twin Turbo these codes are from, but it shoud be close.
Code---- Item to diagnose
11 Crank angle sensor
12 Starter switch
13 Cam angle sensor
21 Water temperature sensor
22 Knock sensor
23
Airflow sensor
Pressure sensor
24 ISC valve
26 Inlet temperature sensor
31 Throttle sensor
32 O2 sensor
33 Vehicle speed sensor
35 Canister purge solenoid
38 AT coordination control
44 Supercharge pressure SOL
45
Absolute pressure sensor
Atmospheric pressure change
over solenoid
51 Neutral switch
54 Abnormality in inlet line
61 Inlet control solenoid
62
Exhaust control solenoid (negative
pressure)
63 Relief solenoid 1
64 Relief solenoid 2
65 Differential pressure sensor
66 Twin and turbo system
67
Exhaust control solenoid (positive
pressure)
68 Exhaust valve duty solenoid
85 Charging line
87 Variable inlet solenoid
89 AVCS system
91 TCS relief valve solenoid
12 Starter switch
13 Cam angle sensor
22 Knock sensor
23
Airflow sensor
Pressure sensor
24 ISC valve
31 Throttle sensor
32 O2 sensor
45
over solenoid
51 Neutral switch
62
pressure)
67
pressure)
85 Charging line
89 AVCS system
I would possibly take a guess at the MAF sensor, but you should pull the codes to see what / if any codes are stored.
