Sti pink springs replace stock turbo springs?
thehookeup
can i put '06 STI springs on my legacy? cause i found a set for 60 bucks. but i just want to know if i can just swap them out with the stock springs.
-93 2.2T (RIP), 93 N/A best car on earth.
-00 legGT, 18" PIAA sport mesh wheels, front/rear Rallitek sways, lowered whitelines, coming soon: 2.5L sti internals, 20g heads P&P, twin charged. motor is almost ready to go in.
Andrew
Andrew
They aren't pinks if you found em for $60, but they'll definately not be setup properly for your stock struts.
the thing about the pinks is that they're the same thing as 04- USDM STi springs (which do sell for less than $60), but are sold for the WRX. I thought it was amusing when subiegal told someone on nasioc that the STI springs wouldn't be compatible with WRX struts but the pinks, with spring rates of 224f/194 r, work fine and give a slight drop. Gee, it's like the words came right out of the SPT catalog.THAWA wrote:They aren't pinks if you found em for $60, but they'll definately not be setup properly for your stock struts.
Either way I would not use them on stock struts.
Actually not quite. The SPT pink wagon spring is apparantly the same as the 04 STi spring
http://forums.nasioc.com/forums/showthread.php?t=983164
Some of the pinks are, but there are at least seven different pink springs I can think of off the top of my head. Still, if they're going for $60 I highly doubt they'll be pink anything, unless it was painted afterwards.
