Exhaust/engine parts question on swap
I am replacing an ej22 engine in a Subaru legacy with another EJ22. The problem I'm having is that the exhaust manifold on the original engine has one hole (two bolts) and the new engine has two holes (three bolts). Is there an easy fix for this problem?
sammydafish
You can get the front pipe off a 95 or 96 legacy. It'll have the 2 port exhaust. You must have a 97+ 2.2 They are the rare bird subaru exhaust wise. Everything else is 2 port. Actualy a front pipe off an EJ25 car should work too.
- Junior
95L Wagon on T3/T4 boost :)
Auto Salvage
Thanks,
I'm off to call the junkyards.
MRtuningCO
