The instal of the A P Racing front brakes required use of 3mm spacers.
Second gen Forester wheels accomodate the 310mm rotors and calipers with lots of room. The first gens I'm using needed spacers.
Should I use longer studs, and if so where can they be obtained
edited for a dreadful typo
3 mm i wouldnt worry about just make sure your torque them right. i know that once you really need new studs, not sure about every company, but i know H&R actually has studs in the spacers
93 White Legacy Turbo Wagon: For Sale-ish
93 White Turbo Sedan: soon with a little more umf
91, funky brown purple gray color, legacy L Wagon: the "its so cheap i cant not pass it up" purchase to get me around when the others are down
Using McGard spline drive lug nuts torqued to spec.
5 out of 6 threads engaged.
