short throw shifter?
crawlerdan
Vendor
Vendor
Post by crawlerdan »
what short shifter will work for my 94 legacy?
1998-2004 impreza 5spd?
subaru part # is c1010fa001
if this wont fit, what can i buy that will?
There is no short shifter that will work with the stock linkage & joint, however you can swap to the new style shifter joint & wrx linkage and use pretty much anything meant for the WRX.
http://bbs.legacycentral.org/viewtopic.php?t=16268
http://bbs.legacycentral.org/viewtopic. ... rt+shifter
crawlerdan
Vendor
Vendor
thanks a bunch man, i appreciate it alot!!
later-=dan
206er
Post by 206er »
I cut mine apart and TIG'd an extension piece between the pivots so you might consider that.
livestrong14
Post by livestrong14 »
Will this work on a 91' sport sedan?
http://cgi.ebay.com/Racing-Short-Shifte ... dZViewItem
91 SS -Carbon Bronze Pearl
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
91 Rio Red SS- RallyX Project
93 AWD Sedan- FOR SALE!
Adam West
Post by Adam West »
No. Remove your shift boot and look at what you've got there...that would be female to female. You gotta replace the linkage like the above message says...
legacymax
Post by legacymax »
I am bring this back from the dead i know but i found this: first one
http://www.bmracing.com/index.php?id=pr ... &subcat=15
95 impreza Rally car. 3.0 H6
88 Toyota fj62 OME lift.
livestrong14
would that fit a 91-92 aswell?
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
n2x4
Post by n2x4 »
The first shifter on that link is for a SRT-10. If you mean this one:
http://www.bmracing.com/index.php?id=pr ... 15&pid=195
Then it won't fit the 90-92. Just look at the difference between the versions, not even close.
SUBARUEHS Racing
If it fits a 92-94 legacy, it should fit a 90-91.
You'd probably have better luck fitting this guy in:
http://www.bmracing.com/index.php?id=pr ... 15&pid=198
legacymax
Post by legacymax »
n2x4 wrote:The first shifter on that link is for a SRT-10. If you mean this one:
That is the link i wanted.
-max
Adam West
Post by Adam West »
Won't work on our cars tho. Not without updating the rest of the linkage.
