if you're just trying to get a car togeather it would work well. its USED, and the friction disc would ideally be swapped to a new one, but i'd guess it would live for a 6 months or so if you ran this friction disc. mab more if you are nice
a good used flywheel is avail for $30 extra
just cleaning out the spares bin. have SOO many spares, figure sombody here can put them to good use.
JDM wrx clutch is direct plug and play with any turbo car trans. so usdm WRX, or legacy SS or jdm or EDM or ukdm, all 5speed subaru clutch turbo style pull.
will not work for NA trans.
