Rear door locks
Manarius
Rear door locks
Post by Manarius »
Well, today I finally tackled the Hobie Gary Door Lock Mod. Had to run down to Lowe's to get some 18G wire and that was all I needed...aside from tools. Took me about 45 minutes to do the first one and 20 minutes to do the second one.
I used the wire to tie up the L shaped spring end (which is inside the big plastic piece of the lock - Gary had me confused on his one) then I tied the wire around two notches for attaching the lock to the door. Like Gary said to, I made some "adjustments" to the door by prying on the holes a bit, then I had to use a little "persuasion" on the locks to get them in with the wire tied around their catches. I also broke a tab on the plastic cover to the lock...glued it but I don't think it's going anywhere anyways.
Now though, I don't have to tell people why my locks are retarded, because they aren't any more!
If anyone needs assistance on how to do the mod, ask me or see this link: http://www.geocities.com/hobiegary/locks.html
Key Words for the Search: Rear Door Locks locking when being opened
0perose
Post by 0perose »
damn.. did you take any pics?
yo mang, can I get a rootshell?
1991 N/A, 4eat, crazy lights, junk suspension, sticker wagon
1989 xt6 work in progress
Manarius
Post by Manarius »
0perose wrote:damn.. did you take any pics?
Unfortunately, no. I didn't have access to my camera.
You can't really get pics of the busted lock part anyway, it's inside the lock toggle assembly.
Read that link carefully and take your time, it's not too hard to figure out. I used that guide and I've done 3 of my doors.
A small mirror can be helpful, and remember to test the handle and adjust the wire tension.
IronMonkeyL255
Post by IronMonkeyL255 »
I used that guide and successfully did two of my doors. I actually used bits of a cut up wire hanger, though, so my driver's door lock sticks out a bit from the door panel.....
Rio Red '91 Legacy SS
Binford
Post by Binford »
Wow, I've never heard of this problem before. How common is this?
Manarius
Post by Manarius »
Binford wrote:Wow, I've never heard of this problem before. How common is this?
I think it's fairly common. Even Josh did it to his car.
You don't need to buy anything....just use a paper clip. That's what I used.
I need to do the rear doors as well.
