completed grounding mod ...results??
boro
Post by boro »
So I did a simple grounding mod today. All I did was ground the o2 sensor housing to the pass. side strut tower, at the existing sensor ground. Also I ran a wire from the negetive terminal on the battery to the alternator bracket.
The results:
My windows roll up a hell of a lot faster...
Ther also was a very slight reduction of low throttle hesitation at first.
Today was a bad test day. I think it was around 105 all day.
If it cools off any I'll mark the progress, if any.
Also, it shuts down smoother. It used to sputter out a bit, but now it shuts down a little faser.
