1990 non-turbo legacy cold air intake
Saskatoon Subaru
does anyone know of any cold air intakes that are made for my gen of legacy
thehookeup
i have heard of guys using ones for the 2.5NA motors. there are threads just do a search. plus anyone made for a 2.5 might need a lil fab , maybe even none
-93 2.2T (RIP), 93 N/A best car on earth.
-00 legGT, 18" PIAA sport mesh wheels, front/rear Rallitek sways, lowered whitelines, coming soon: 2.5L sti internals, 20g heads P&P, twin charged. motor is almost ready to go in.
Andrew
Andrew
Saskatoon Subaru
cold air intake for '90 legacy
I am also looking for a cold air set up for my '90 legacy sw. It looks like weapon R makes one.
www.boxer4racing.com has one for impreza 2.5 that looks like it would fit perfectly..
i'm trying to figure out a way to install my cone filter using the stock tube.(abs pump is in the way)
94 legacy gt wagon/tinted windows/dynamat/200w kenwood
japanesecowboy14
I picked up a generic cone filter from autozone for like 30 bucks. the mod was simple improv. I took out the airbox, and pulled out the little gold flange it used to connect to the MAF, use a sawzall to cut pipe back 3 inches, refit the MAF to new location, & used a silicone gasket maker to seal the cone to the flange & bolted it back to the ecu. it will make for a perfect fit, and if you're high altitude, there WILL be an increase in performance & mileage. i didn't get much for HP, except like 4HP or so, but i went from 22 to 28MPG highway.
