Whiteline Products
FrmRgz2Rchz
Whiteline Products
Post by FrmRgz2Rchz »
I heard whiteline makes the best suspension parts for Subarus, but I can only find an anti-lift kit for our car from them. I also found a swaybar on ebay, but it's not for the US spec. Are there any parts, for, say an impreza, that I could make work with some modifications.
Andy Rose
1993 Subaru Legacy Sport Sedan
2003 Subaru Impreza WRX
2004 Subaru Impreza WRX STI
1999 Hyundai Accent
ciper
Post by ciper »
You should visit the whiteline sight, find the pdf with the product listing, write down the part number then find a whiteline distributor and order the part.
Any real whiteline distributor can get any of the parts listed. Usually they can have them shipped directly to you from whiteline.
FrmRgz2Rchz
The problem isn't that I can't find anything for our cars, it's that they don't make anything for them other than the anti-lift kit.
Andy Rose
1999 Hyundai Accent
ciper
Post by ciper »
You must not be looking in the right place....
I have:
Anti Lift
Front strut brace
Front 22mm sway bar
Front 22m hardened bushings
front sway bar links
Rear 18-20-22 sway bar
Rear 20mm hardened bushings
Rear HD sway bar mounts
Rear sway bar links
All from whiteline.........
Aaron's ej22t
Post by Aaron's ej22t »
they make 30mm drop springs too!
92 Legacy Turbo \ 5MT \ Silver
rallysam
Post by rallysam »
Look around the popular Subaru performance parts dealers online. Here are some that list other Whiteline parts for Legacies online.
http://www.mrtrally.com
http://home.att.net/~teaguesauto/index.htm
If the problem is that you see parts listed for newer generation Legacies only, instead of our BC-BF's, ask these for the authoritative answer. Many parts transfer and I guarantee someone on this list has tried it :D
Sam
90 Legacy L Wagon awd
rallysam
Post by rallysam »
Oops, typo.
I meant to say "ask these forums" for the info
Sam
ciper
Post by ciper »
Oh yeah, I have whiteline springs on the front.
Here's is Whiteline's application guide for springs
http://www.whiteline.com.au/docs/catalo ... D3_app.PDF
Here's their full catalog (warning 1.44mb) http://www.whiteline.com.au/docs/catalo ... 3_full.PDF
As far as suspension stuff goes....pretty much anything you can put on an impreza will work in some form on our legacies......there's a couple tid bits and complications depending on your particular year....but should work.
kelley
Vendor
Vendor
Post by kelley »
I just installed a set of sti (new age wrx) struts and springs w/ sti top hats.
so ( I would think) any impreza suspension part should work
Aaron's ej22t
i just got rear endlinks in the mail for $41 shipped. i would like to install them tomorrow. :o
rallysam
Post by rallysam »
Although, I've heard one impreza part that doesn't transfer to the Legacy is the rear sway bar, because Legacies have a bigger bulge for the spare tire or something like that.
rear anti-sway bar would be something I would recommend on getting a car specific part.
ciper
Post by ciper »
Thats right. The impreza bar has only 8 bends while the bc-bf bar has close to 20!
mTk
no title
Post by mTk »
Would like to drop a good word in for PDM-RACING
I have ordered all of my whiteling gear from them, excellent prices and customer service.
MK
1992 BC672 AWD 5MT
My beef with PDM is they don't want any phone contact. I don't like that.
I can usually find comparable prices else where that don't mind phone contact....so I go that route......but that's my only beef with them......
