replacing tires, have questions
The Scooby
Post by The Scooby »
ok i have legacy 2.5GT web wheels, they are 6.5inches wide.
i was wondering if 225/50/16 would be to wide for the rims and/or if they are would 215/55/16's be ok
Thanks,
Shean
1986 GL wagon
EJ'ed and Lifted
Imprezive
Post by Imprezive »
Stick with 205/55 or 205/50. If you were gonna go with a 225 width, I wouldnt go over a 45series although that is irrelevant since 225 is WAY to wide for a 6.5" rim. Reason being the sidewall gets pretty squishy with a 225, a 215 is right in the middle any may be worth a try if you find some tires with good sidewall reinforcement.
But that extra 10mm width only adds up to about another 1/3 of an inch wider contact patch. So 7.6" with 205/55 versus 7.9" with the 215/55 series. Not to mention, you gain about 1 pound going to a 215/55 over a 205/55 and you also get a slightly wider section width (sidewall to sidewall width) which in turn creates a softer sidewall.
1988 4Runner RIP
2006 Suzuki DRZ400sm
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
Post by BAC5.2 »
225/55/16 doesnt fit. I have those tires on my Forester, and they rubbed when I put them on for S&G's when I was test fitting the SubZero's on the Forrester.
