A couple of weeks ago my brakes started to squeel under light to medium braking when hot. I took everything apart, cleaned, inspected and reseated the pads and it didn't seem to have any affect on the noise. Should I try reseating the pads a second time? Any other suggestions? Thanks.
My setup is as follows:
-WRX front calipers
-Racing brake rotors
-Hawk HPS pads (w/ 50%+ pad life)
Excessive Brake Squeeling
'06 Impreza 2.5i wagon
Hmm....
Well, you've eliminated any of the problems I've had contribute to brake squeeling. If everything is tight, you have your clips in and brake glue/goo on all the metal to metal contacts, and the pins are in good shape, I'm not sure what to tell you.
I pressume you also checked the caliper to bracket bolts?
I also pressume you're running Hawks in the back too and they are quiet?
And it only does it when they're hot?
Lee
