Did a do something bad
Carbix
Post by Carbix »
Well i stuck in normal power steering fluid insted of what the cap said. em i F*#$ed? :?
|====.[Legacy. Central].====|
|=+[Leaving A True Legacy]+=|
You'll be fine. I ran normal power steering fluid for too many years to count. It probalby wouldn't hurt to put ATF in....but it shouldn't kill your pump or anything.
Carbix
Post by Carbix »
cool thanks
DLC
Post by DLC »
When I realized that the funky stuff my power steering was doing was as a result of having low fluid, it actually took some convincing to get the parts store to check and make sure that his books agreed with my manual for ATF.
Legacy Central
Brat4by4
Stratified
Post by Brat4by4 »
I had a weepy rack when I first got the car (only leak the car had). So I was in Walmart and saw some stop-leak power steering fluid stuff... figured I give it a try and it worked. No more weeping for over 3 years and not one complaint from the steering rack from lock to lock.
That was before I knew the power steering fluid took ATF... but it seems to be just fine.
