Warped rear rotors--Suggestions
Subtle
Post by Subtle »
The two-week vacation driving around Southern B C and Northern Washington was good. Now it's back to work and wearing socks :? . Only one day with a rain storm. :)
Installed new vented rotors on the rear just before leaving-- no vibrations when braking.
Went down one mountain pass with up to 15% grades at 95F. No spectacular braking as the traffic was slow and almost continuous. Then coming down after a day of mt biking on Silver Star the old vibration came back.
Rear Rotors were from BrakePerformance.com
Not Pleased :cry: --will try the factory ones.
jamal
Vendor
Vendor
Post by jamal »
Are you sure it's coming from the rear? Rotors tend to not actually warp. Unless you unevenly/over tighten the lugs.
What pads are you using and did you bed them in properly?
I suggest reading some stoptech white papers. They know their shit.
Yeah, it would be strange for it to be the rears over the fronts. Not much power goes to the rear comparatively either. I warped non-cryo rotors in so that they'd pulse intermittently in weeks, badly enough to pulse strongly the majority of the time in a few months.
jamal
Vendor
Vendor
Post by jamal »
I have crappy rotors and crappy pads and absolutely beat on my brakes sometimes. I was in a road rally in may and actually had smoke coming out of the wheels at a control. All my lugs are properly torqued and I bedded in my brakes according to stop tech. No vibration. One of these days I'll do that brake swap. I've had wrx calipers and pads and ss lines for over a year now.
tonflo
Post by tonflo »
I've never heard of anyone warping rear rotors. Are you sure it's the rears? Any way you can check with a gauge or something fixed to see if they have a wobble? Could it be pad residue built up on the rotors?
'94 Legacy Touring wagon. Quicksilver metallic. WRX rims, Whiteline ALK, SS brakelines, GR2s, alum. coolant tank. Gone, but not forgotten
'99 NSX, Alex Zanardi edition, #11/50. All stock & red 2 go
'05 Corolla XRS
Subtle
Post by Subtle »
At hard braking from higher speeds the vibs are only minor.
However, on moderate braking at slow speeds it is getting worse and last night even noticed a slight shudder while turning at slow speeds with no accelerator or brakes.
Something wrong with the tie-rods or whatever :oops:
Fuzzylee
Post by Fuzzylee »
Brake rotors don't actually "warp".
Tonflo has it.
It's uneven layers of pad material on the rotors that causes pulsing (slide-bite-slide-bite..etc.)
Resurface the rotors(very fine grit sandpaper?Scotchbrite pad?), and rebed(?) the pads.
Subtle
Post by Subtle »
My experience on this is that I bot the twgn 4 years ago and earlier in the year things were beginning to vibrate under hard braking.
In preparing for some track time, I put on the AP Racing front kit with new SS line to the backs as well. Pads are Ferodo DS 2500 front and back.
Both installs were properly bedded in.
Although diminished, vibs were still there. Put on new vented rear rotors and the moderate vibs went away. :-)
Then, as in the initial post, they came back.
Going out to PDM Racing to have the ride height lowered to stock now that the back road season is over, and with redoing the alignment and all I'm sure we'll figure out the problem.--- :)
We live in hope.
Bheinen74
Post by Bheinen74 »
earlier, you mentioned vibrations while turning, but without applying brakes. That my friend, is a wheel that is out of balance. it will also cause pulsations when braking. but 100%+ its your wheels and they need to be spin balanced. could be otherthings in addition, but vibrations whole turning and no brake useage=time to go to a tire shop to have a spin balance, or maybe even new tires.
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
All_talk
Post by All_talk »
Fuzzylee wrote:Brake rotors don't actually "warp".
Tonflo has it.
Brake rotors DO warp, I have turned them myself and seen more than .020 of thinkness variation (more than a .002 or so and you can feel it in the pedal).
But yes, pad imprinting can cause a vibe or pulse as well, most common cause is leaving the brake pads held against rotor after a hard stop.
In the case at hand I'd take a good look/feel of the axles, try slow figure eights with the wheels at full lock, listen for clicks and feel for ratcheting.
Gary
jamal
Vendor
Vendor
Post by jamal »
All_talk wrote: Brake rotors DO warp, I have turned them myself and seen more than .020 of thinkness variation (more than a .002 or so and you can feel it in the pedal).Gary
Have you read this?
IronMonkeyL255
Post by IronMonkeyL255 »
Interesting article, but brake discs can warp. Maybe it's not as common due to people mis-diagnosing the problem, but it does happen.
That being said, I need to turn my rotors before I go to the dragon next........
Rio Red '91 Legacy SS
Bheinen74
Post by Bheinen74 »
Tonflo has it.
they do warp. All you have to do is watch a rotor being turned on a brake lathe to see this. It is a more common thing in Mountainous states to get warping/and or "glazing", do to the constant braking on decents out on the highway. That article is written on a basis, but not on real automotive experience.
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
Ok....we need to clarify what warping and DTV are.
Warping would indicate that the brake rotor is not true based upon the centerline of the rotor. If this was the case, there is no amount of turning the rotor that will make it true again.
DTV or disc thickness variations means that the outer portions of the rotor are not true. When this occurs, you can turn them on a lathe or a mill, and get them true again.
jamal
Vendor
Vendor
Post by jamal »
Bheinen74 wrote: That article is written on a basis, but not on real automotive experience.
Maybe everyone should read it again. Also all the other articles on there.
With one qualifier, presuming that the hub and wheel flange are flat and in good condition and that the wheel bolts or hat mounting hardware is in good condition, installed correctly and tightened uniformly and in the correct order to the recommended torque specification, in more than 40 years of professional racing, including the Shelby/Ford GT 40s – one of the most intense brake development programs in history - I have never seen a warped brake disc.
...In fact every case of "warped brake disc" that I have investigated, whether on a racing car or a street car, has turned out to be friction pad material transferred unevenly to the surface of the disc. This uneven deposition results in thickness variation (TV) or run-out due to hot spotting that occurred at elevated temperatures.
I'm sticking with their story. I guess a cheap rotor that's crooked out of the box would be another exception.
tonflo
Post by tonflo »
I have warped my share of fronts & it is definitely visible when they are on a brake lathe. The little tip of the lathe intermittently hits the disc until enough metal is gone to make it straight, then it hits constantly along the disc. Sort of like watching a warped record go around. Never seen someone warp a rear though. I guess it's time to get an Sti with those bigass Brembos. Or a Caddy CTS-V with even biggerass Brembos.
'05 Corolla XRS
Thickness variation would appear the same.
This is one of those automotive lore things that is just wrong. No matter how much you try to explain it to people or provide evidence, they won't believe it. Similar to detonation....but I won't get into that here...
You mean detonation vs. preignition? I know what you mean.
sort of.....but even more so then that.....detonation is a pressure wave induced combustion/ignition of air & fuel. This doesn't happen. You're actually getting auto-ignition. All the gasses spontaneously ignite.
I just recently found that out at an engines class. It's one of those terminology things.
Richard
Post by Richard »
CTS-V? If you got that kind of money spare a brotha a coulpe bucks for some blue brake fluid! J/K
tonflo
Post by tonflo »
If I had that kind of money my Subaru wouldn't be my daily driver & the NSX would be paid off. :D
'05 Corolla XRS
There's an NSX near me that I haven't seen move out of its spot in the driveway for about 6 years. I don't know if someone died and the parents won't part with it or what, but it's a shame. It's an early 3.0 model and I wonder if I could pick it up relatively cheap, but I wonder it to myself just in case they'd actually sell it cheap and then the sissy pragmatist in me would get his ass kicked.
Richard
Post by Richard »
Its worth a try. You never know until you ask.
tonflo
Post by tonflo »
It can't hurt to ask, you may get a deal if they don't know what it's worth. Keep in mind if they do, used NSXs in good shape of that era are still $25K-$32K cars. You may want to get it checked out at mechanics direct (http://www.mechanicsdirect.com/) if it is for sale. Maintenance,especially if it is past due & neglected, is much more than any Subaru. This could also lower the price if it needs timing belt, water pump, clutch, hoses, etc.
'05 Corolla XRS
