If anyone is around, i need some help real, real quick.
I did search, but I cant find this out...
When I try to loosen the topmount nut, the bolt its on just rotates. I cant figure out any way of holding the bolt still while I turn the nut.
I dont have a 17mm wrench... only sockets.
I do have a bit that fits inside the bolt tho
Removing topmount nut
Both of those solutions are good. The other thing you can do is use an impact wrench, since the impact action tends to break the nut loose while the inertia of the damper shaft holds it still (at least for a second).
'00 Impr RS - sold
You can also buy a set of nylon jaw "channellock" type plyers that you can hold the shaft with to keep it from spinning, makes sure the shaft is clean first. Can help on the stubborn ones that dont want to come off.
...::Slide your ride::...
[url=http://www.driftsub.com/]^driftsub^[/url]
[url=http://www.sloganizer.net/en/]>I wish i was a driftsub<[/url]
