Putting turbo on a non-turbo without engine swap
does, anyone know if its possible to put a turbo on my non-turbo 90 legacy with out an engine swap. And does anyone know the cost's that would go along with it, thanks
2010 Impreza WRX - 265hp
1990 Legacy 267,000km(Rebuild complete 265,423km----March 9/2008)
1991 Legacy Turbo 180,000km
My friend... anything is possible... just depends on your budget...
But really, I see that your engine has a lot of miles er.. Km so I would recommend a rebuild before a turbo kit. The turbo kit will all depend on what kind of performance you want. The bigger the turbo/more power obviously the more money. I would say though do the motor swap... it will be cheaper in the long run.
Hope that helped a tad
Korean
PS. EJ22T motor swap... FTW!
![Mad :x](./images/smilies/icon_mad.gif)
Korean
-Jonny Walker
-2005 RHD and Flared Legacy GT Wagon 5mt
Yes.
But you are limited to about 4 psi until you need injectors and engine management, intercooler, a lot of money.
I have gone through 3 NA motors boosted. I know the truth!
First thing is to define exactly what your looking for. If its 130 whp and you wanna spend the money on a NA/Turbo build then go ahead. Its not going to be as reliable as a true EJ22T but it'll work. Not exactly sure of the limitation of the open deck NA block but I wouldn't try pushing much more than 200 chp without some major $$.
You will probably spend less time and money on an actual EJ22T swap. Plus once you get the EJ22T in...thats when the fun begins. You get to play with upgrades.
There are some other options if your inclined. A 2.5 engine will fit in your engine bay and I have read a post of someone putting the H6 under the hood of the legacy. Or you could go the Douglas Vincent route with a Super charger...I am VERY tempted!
