Turbo and Non turbo IAC
TurboSubie
Post by TurboSubie »
Are they the same? My Idle is jumping around like crazy...no CEL tho..is it possible to clean this thing? Tried electrical cleaner to no avail.
1994 Aegian Blue Subaru Legacy Sport Sedan. Mean Muggin.
1995 Honda CBR 600 F3 D&D complete system,K&N, few other things..
douglas vincent
Post by douglas vincent »
1990 NA IAC valves do not swap. I know that much. However.......You can make a 1/4" thick aluminum plate adapter that will allow it to work.
sammydafish
Post by sammydafish »
douglas vincent wrote:1990 NA IAC valves do not swap. I know that much. However.......You can make a 1/4" thick aluminum plate adapter that will allow it to work.
that's why I did to make my IAC work with a MY00 EJ25 manifold.
- Junior
95L Wagon on T3/T4 boost :)
napphappy
Post by napphappy »
Otherwise its just the fact that the turbo IAC has the metal elbow on it. The NA has a straight inlet, which makes it VERY hard to plumb on a turbo.
crushn8r
Post by crushn8r »
Can the IAC be removed by taking the top two philips screws out and pulled out the top of the housing, or does the whole assy need to be unbolted from the intake (four bolts)?
1992 BJ 5mt slicktop liquid silver
napphappy
Post by napphappy »
If your IAC is bad electically, then yes you can just replace the top part. But if the mechanial part(bearing, thermastat, ect..) is bad you will have to remove the whole thing.
If you remove the top, be sure to mark where to put it back.
crushn8r
Post by crushn8r »
And removal can be done without taking off the intake manifold? Looks like the bottom two bolts are obscured by a portion of the IAC body. Any advice?
TurboSubie
so it looks like im going to need a turbo IAC..any spare ones out there?
You need to be cautious about just swapping the electronic part. It can be done, but the electronic part is matched to the valve, and there are slight differences.
