Give me power :)
PJHARJ
Give me power :)
With the installation of the MY'97 intercooler quickly approaching I am now
looking for answers regarding engine managment. At what point does it
become neccesary to add control units for ignition and fuel? Or, at what
point does the stock ECU become unable to compensate for increased boost?
I am currently running the "reroute vacume hose" mod which netted me
12 -12.5psi, only at high ambient temps (above 90 degrees) do I sense the
ECU pulling timing, otherwise all seems well.
Soooo, how far can I go before I need expensive electronic toys and what
will need tweaking first, fuel or ignition?
PeteH
'92 Turbo Sport Sedan, 5-spd of course!
PeteH
Matt Scicchitano
Give me power :)
Or, at what
boost?
what
> PeteH
Pete, just by going from what the Mitsubishi guys practice, I would
say fuel would be the first concern. As long as you have enough fuel,
I don't think you'll get into trouble. Being that our cars are
factory Turbos, I would think the ECU is capable of running your
engine for quite some time. Maybe bigger injectors and a bigger fuel
pump, possibly a fuel controller to fine tune everything and I would
think you should be OK but that's not coming from hands on experience
so I don't know for sure. With a 8.0:1 compression ratio, adequete
fuel and a good intercooler, I don't think you would have to worry
about timing for a while, if at all.
BTW, does anyone know ~FOR SURE~ what size injectors the Turbo
Legacys have?
boost?
what
> PeteH
Legacys have?
Matt Walters
Give me power :)
At 048 PM 10/8/2000 +0000, you wrote:
>Or, at what
>boost?
>what
> > PeteH
>Legacys have?
360-380cc/min.
-=[Matt]=-
>Or, at what
>boost?
>what
> > PeteH
>Legacys have?
360-380cc/min.
-=[Matt]=-
William D. Robinson
Give me power :)
The Legacy Turbos have 389cc/min injectors that are considered maxed at
80% duty cycle.
The Superchips folks say that our fuel amd ignition map curves are okay
for at least 14psi. To the best of my knowledge, injectors are a
limiting factor. The fuel pump connector under the back seat is
problematic. If you haven't done so already, solder a jumper around that
little bastard. Your car will gradually become less and less sporty as
the white connector turns brown.
I am still screwing aroud with knock sensor, atmospheric pressure sensor
and mass airflow meter ECU errors, so I am nobody's expert on much of
anything. I am gradually going back to stock ecu control etc. as I
attempt to sort things out.
My ISP is going broke this week so I am now vultureboy@mindspring.com.
What is the prodedure for switching so that this bulletin board
acknowledges my new e-mail?
Bill Robinson
92 Turbo 5-speed
Matt Scicchitano wrote:
> Or, at what
> boost?
> what
> > PeteH
> Legacys have?
80% duty cycle.
Bill Robinson
92 Turbo 5-speed
> Or, at what
> boost?
> what
> > PeteH
> Legacys have?
Matt Scicchitano
Give me power :)
--- In BC-BFLegacyWorks@egroups.com, "William D. Robinson"
maxed at
> 80% duty cycle.
Thanks guys for the injector size. I thought I remember Paul Eklund
saying they were in the 380cc range a while back. I'll put it in the
FAQ. Now, that being said, is there a rough estimate of how much
boost you can run with the stock turbo before the injectors begin to
go above 80 percent? I know there are many variables that need to be
considered but just a rough idea would be great.
BTW, thanks for the tip about the connector Bill, I will check that
tomorrow.
maxed at
> 80% duty cycle.
tomorrow.
William D. Robinson
Give me power :)
I typoed!!!! The USA Legacy injectors are 380cc/mim, not 389cc/min. They
are quite a bit smaller than the injectors on an EJ20G, so the USA Legacy
(EJ22T)ECU has a longer pulse duration.
Yesterday I sucked a half a can of Seafoam brand decarboniser through my
engine. It spewed a lot of nasty fumes etc, but I still have a knock
sensor error code on my ECU
Bill Robinson
> >Or, at what
> >boost?
> >what
> > > PeteH
> >Legacys have?
> 360-380cc/min.
> -=[Matt]=-
Bill Robinson
> >Or, at what
> >boost?
> >what
> > > PeteH
> >Legacys have?
> 360-380cc/min.
> -=[Matt]=-
mike p.
Give me power :)
--- In BC-BFLegacyWorks@y..., "William D. Robinson" <billrob@i...>
maxed at
> 80% duty cycle.
okay
around that
sporty as
ok, so can anyone tell me for sure what the connector looks like that
would be problematic? i had my back seat out a while back and looked
for it but i don't understand what he's talking about.
FREE COLLEGE MONEY
CLICK HERE to search
600,000 scholarships!
http://us.click.yahoo.com/47cccB/4m7CAA ... /XoTolB/TM
maxed at
> 80% duty cycle.
okay
around that
sporty as
FREE COLLEGE MONEY
acroxford@hypermall.net
Give me power :)
The fuel pump connector is under the lower part of the rear seat on
the passengers side. It may be wrapped up with something and hard to
see at first. It is a good idea to jumper this plug as more than one
car has gone up in smoke because of this little item. On injectors if
we went to larger injectors I think we might have a problem with the
low end and milage would probably get worse. The quickest cars around
here have additional injectors that open when boost calls for more
fuel.
> maxed at
> > 80% duty cycle.
> okay
> around that
> sporty as
that
looked
FREE COLLEGE MONEY
fuel.
> maxed at
> > 80% duty cycle.
> okay
> around that
> sporty as
that
looked
FREE COLLEGE MONEY
mike p.
Give me power :)
ok, my next question, what would a suitable jumper for this
application be? just a short wire around it, what guage would you
recommend?
to
one
if
the
around
> fuel.
<billrob@i...>
> > maxed at
> > > 80% duty cycle.
are
> > okay
a
> > around that
> > sporty as
> that
> looked
FREE COLLEGE MONEY
recommend?
to
one
if
the
around
> fuel.
<billrob@i...>
> > maxed at
> > > 80% duty cycle.
are
> > okay
a
> > around that
> > sporty as
> that
> looked
FREE COLLEGE MONEY
Give me power :)
Any wire with good insulation and about the same gauge as was used on
the original wiring or a little larger would work fine I think that
the original was 16ga stranded. The problem wasn't with the wire the
connector was a little underated and you wouldn't need much wire
maybe
a few feet.
> recommend?
on
> to
> one
injectors
> if
> the
> around
more
> > fuel.
> <billrob@i...>
considered
> > > maxed at
> > > > 80% duty cycle.
curves
> are
> > > okay
are
> a
is
> > > around that
> > > sporty as
like
> > that
> > looked
Monitoring Service trial
http://us.click.yahoo.com/MDsVHB/bQ8CAA ... /XoTolB/TM
maybe
a few feet.
> recommend?
on
> to
> one
injectors
> if
> the
> around
more
> > fuel.
> <billrob@i...>
considered
> > > maxed at
> > > > 80% duty cycle.
curves
> are
> > > okay
are
> a
is
> > > around that
> > > sporty as
like
> > that
> > looked
