electric window difficulty
Redlined
Post by Redlined »
my Drivers side window has difficulty rolling up and down. it will move on its own, but it *hangs up* in 3 different spots and the motor does this Rat tat tat tat tat Ratcheting noise.
Loose Clutch? Bad Motor? Window guides Messed up? What do you think?
Help!
Thanks in advance!
Manarius
Post by Manarius »
Sounds like a toasty motor to me.
jnorion
Post by jnorion »
Ratcheting noises are usually gears skipping...
~Joel
IronMonkeyL255
Post by IronMonkeyL255 »
What about for really slow windows?
Mine are crazy slow, and it's starting to annoy me.
Rio Red '91 Legacy SS
Post by entirelyturbo »
Crazy slow means the motor's probably worn out. My passenger side takes longer to roll up than any other window, so I don't use it very much just in case it dies and my window is stuck down :shock:
Ratcheting noises probably means the regulator is coming apart. It would surprise me, because our regulators are gear-driven, so it's hard for them to fail. But I dunno what else it could be.
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
