Raquel is dead
Raquel is dead
Serious this time.
The crank pulley got loose and smashed itself to bits, and the crank bolt is broken off inside the crank shaft.
The car was IDLING when this happened.
Any advice on what to do?
start praying that you didnt bork the block and get parts for 2.35L?
get a cheap ej22e for the crank?
or, can you tell how loose the crank bolt was when stuff started to happen? if the keyway is not totally chewed and you dont think that the crank bolt was fully tight you could try an EZ out. would be a pretty damn scary/difficult procedure to do though. maybe the rad and AC condenser would have to be pulled, or get one of the snubnose drills. good excuse to get more tools eh?
My condolences go out to you Splinter.
Subaru did a great job with their engines, except that damn crank pulley...
What kind of condition is the end of the crankshaft in? I pressume it's a bit rough but is there enought to shim and mount a new pulley on after exracting the old bolt?
Lee
Damn, sorry to hear that Splinter.
stock pulley or aftermarket?
had you already taken it off once before or this is just stock never been touched on that block?
James L
'07 Magnum SXT - not stock
'93 Legacy Turbo SS - 5spd conv, vf34, intercooled, K&N, dual stage mbc 11/16psi, hks 3" turbo-back w/hi-flow cat, kyb's, ADR 18" rims w/225/35/18zr's, 7" touch screen w/race camera
that fucking blows steve!!!!!!!!!
i think its time for a stroker motor
chances are that even if you get the rest of the bolt out its chewed up the keyway to much for it to be any use... that means ripping the motor out and replacing the crank. i do know a place to get a brand spanken new OEM 2.2t crank for $100+shipping (i got one for my new motor)
Sucks man! I'm sorry to hear my car's evil twin is ailing!!
Hey, is that really a problem with our cars? Never heard of it. Ive got a Perrin lightened pully - am I playing roulette?
douglas vincent
Damn!!!!!!
I just realized who was posting this.
So sorry to hear. But I feel your pain, as I fucktarded my motor on Saturday.
Radial GT1
This is the second person I have heard of the crank bolt snapping. Is the crank warped or what is it that does this? Should I be worried about mine?
I have taken mine off to replace the timing belt and impacted her back on.
What special precautions should a person take with that?
00 Camry; No wrenchin', just drive. Thank you Japan!
93 Legacy SS 4Eat 96K; All the wrenching I could ask for.
[quote="un-named"]What a man & a woman, and another man with a sheep & a midget want to do is their own business...[/quote]
you guys and your bad mojo.... now i'm scared to put my new motor indouglas vincent wrote:Damn!!!!!!
import_freak
The torque spec is wrong. 110-120 is what you want. It's like the bullshit 65 spec for the lug nuts. Great if you want them coming off in a corner.
thehookeup
