So for some reason on my 2.2 turbo i dont get spark on 1 and 2 but do on 3 and 4. Car wont start just keeps turning over and backfiring occasionally. Got fuel... timing is correct... Switched out multiple coil packs and ignitors. Its not the plugs or the plug wires cause ive tested them. Im going back outside to check the wiring. anyone ever have this problem or is there anything else i forgot to check? At first i thought maybe cam or crank sensor but then why would i not receive spark on 1 and 2 but 3 and 4 all day long?
PLEASE HELP!!!
Help ASAP!
Help ASAP!
93 White Legacy Turbo Wagon: For Sale-ish
93 White Turbo Sedan: soon with a little more umf
91, funky brown purple gray color, legacy L Wagon: the "its so cheap i cant not pass it up" purchase to get me around when the others are down
have you cleaned up the place where the coil pack mounts? iirc this is how the coilpack gets ground.
my initial thought was that you had a bad coilpack but if you've tried others that's unlikely...
yo mang, can I get a rootshell?
1991 N/A, 4eat, crazy lights, junk suspension, sticker wagon
1989 xt6 work in progress
Re: Help ASAP!
timing belt.gt2.5turbo wrote:So for some reason on my 2.2 turbo i dont get spark on 1 and 2 but do on 3 and 4. Car wont start just keeps turning over and backfiring occasionally. Got fuel... timing is correct... Switched out multiple coil packs and ignitors. Its not the plugs or the plug wires cause ive tested them. Im going back outside to check the wiring. anyone ever have this problem or is there anything else i forgot to check? At first i thought maybe cam or crank sensor but then why would i not receive spark on 1 and 2 but 3 and 4 all day long?
PLEASE HELP!!!
#82 M4 TRSCCA Rallycross
turns out to be wiring grimlins.... switched over the main harnesses like i had planned too and everything worked all of a sudden so ya thanks for the suggestions
